FME_SERVER_DEST_DIR
  • January 17, 2014
  • 80 views
tino
Forum|alt.badge.img+17
i just noticed that if i have more than one writer in my workspace and choose only the output of one for the DataDownload- or DataStreaming-Service only this output gets written to FME_SERVER_DEST_DIR. The other writers write their output to the default, in the workspace file configured path.
How do I avoid conflicting file access with concurrent user session for such a workspace?
I need a unique filepath for a temporary file in my workspace which should not be included in the download/streaming output. I could use a private python parameter which generates a filename (e.g. with a timestamp) or i could perhaps utilize the UUIDGenerator to achive unique filenames...
Or I could use the FME_SERVER_DEST_DIR parameter and extract the unique part of it to use it e.g. in %TEMP%.
But perhaps FME Server has some variable/function i could use directly?
Best answer by kathyross
I'd recommend a combination of a Timestamper and RandomNumberGenerator transformer for forward compatibility purposes in case in future FME Server releases the variable / function (if such exists) changes name.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
Forum|alt.badge.img+4
  • February 3, 2014
