FME Server and Published Parameters
  • Jun 8, 2016 11:07 PM UTC
  • 42 views
Hi All,
I am getting confused with some issues with published parameters and running schedules via FME Server. I can run the workspace manually via FME server, the published parameters are filled, and it runs no problems. When it runs via a schedule, the published parameters go missing and it fails each time due to the published parameters having no value?
Cheers,
mygis
Forum|alt.badge.img+14
  • Jun 8, 2016 11:30 PM UTC
Hi @gisballarat;
You should set "default values" for your parameters in your workspace. Run the workspace without prompting for parameters. If you are satisfied with the result then re-publish your workspace on server.
Also in your case make sure that your server has a connection to the database and that the default folder for your writer exists.
