FME Message #706501
  • May 3, 2024 12:47 AM UTC
  • 0 replies
  • 72 views
chlaw2001
Participant
Hi, as a newbie in FME, I am using a FME ISO8211 reader to expose some of the attributes for further transformers. However, if all records have to be read, a message “Message #706501 is not present in the message file: Parameters are >< and FME HOME is >C:\Program Files\FME\<” was prompted and the whole process was halted.
The FME version I am using is FME2018. Thank you for the kind response!
