FME Form produce erroneus filenames for FFS when (Windows) OS Locale are not en_US
  • Jan 19, 2026 7:19 AM UTC
  • 164 views
palhermans
Forum|alt.badge.img+11
Hi, a client is using nb_NO (Norsk Bokmål) Locale on a Windows Server machine and the produced FFS filename is incorrect. They are using FME Form 2024.2.3.0.
I have tested same om my machine Windows 11, FME Form 2025.1.1.0 - build 25615. I want to produce a filename “t2_æøå”.FFS (where æ, ø and å are Norwegian alphabet letters)
  • using en_US Locale the produced file is t2_æøå.FFS
  • using nb_NO Locale the produced filename is t2_æøå. FFS
I repeated the test wiriting to Esri Shapefiles - and both Locale will give the result t2_æøå.shp. Seems like the FFS writer have an issue with Locale. Might be a known issue  but I was not able to find it. Thanks
Best answer by pierrekoelich
I wanted to provide an update on this thread for other users who may be running into this:
The issue was filed as FMEENGINE-89334 and the fix is available in the FME 2026 Beta, builds 26078 onwards.
Thank you again for reporting this issue and helping improve FME.
palhermans
  • Jan 21, 2026 12:36 PM UTC
Due to lack of response I raised a ticket on this case (#61855)
pierrekoelich
Forum|alt.badge.img+7
  • Feb 23, 2026 10:49 PM UTC
palhermans
  • Mar 2, 2026 7:16 AM UTC
thanks for the update ​@pierrekoelich
