FME Form Floating Lic compatibility with earlier versions
  • Mar 6, 2024 10:19 PM UTC
  • 149 views
mferwerda3
We have FME 2022 with floating lic, with 2 editions, Database, and ESRI.   Would like to install FME Form 2024.0 along side FME 2022.  I know at some point Safe did away with Lic Editions, any idea if we can use the same  FME 2022 lic file and make it also work for FME Form 2024 ?  .
Best answer by hkingsbury
I believe that should be fine. I have versions from 2019 all the way through to 2024 running off of the same license (server)
hkingsbury
Forum|alt.badge.img+73
  • Mar 7, 2024 12:19 AM UTC
