FME_EnocodeText error on parameter
  • Mar 18, 2013 7:50 PM UTC
  • 51 views
I'm trying to run a batch process using the cmd prompt and am stuck on an FME_EncodeText error for my input source shapefile.  The workspace just reads in a shapefile datasource then converts it to various formats and fanouts based on basename.  Any ideas
Y:\\web_processing\\Projects\\Teranet\\postgis_clipper>fme.exe shp_parcel2multi_2013_02_18.fmw --src_shp Y:\\web_processing\\Projects\\Teranet\\postgis_clipper\\parcel_tiles_2013_03\\parcels_1\\parcel174355474302013tera\\Label.shp --FEATURE_TYPES "" --kml_fanout_directory parcel_tiles_2013_03_fme_kml --dwg_fanout_directory parcel_tiles_2013_03_fme_dwg --dgn_fanout_directory parcel_tiles_2013_03_fme_dgn
            Feature Manipulation Engine 2009 (20090106 - Build 5658)
                       FME Professional (node locked-crc)
                               Permanent License.
                         Machine host name is: server17
                           Copyright (c) 1994 - 2009
                               Safe Software Inc.
INCLUDE -- failed to evaluate TCL expression `  set encodedVal [FME_EncodeText {
Y:\\web_processing\\Projects\\Teranet\\postgis_clipper\\parcel_tiles_2013_03\\parcels_1\\parcel174355474302013tera\\Label.shp}];        puts "MACRO src_shp__FMEENCODED__ $encodedVal" ;   ' -- invalid command name "FME_EncodeText"
    while executing
"FME_EncodeText {Y:\\web_processing\\Projects\\Teranet\\postgis_clipper\\parcel_tiles
_2013_03\\parcels_1\\parcel174355474302013tera\\Label.shp}"
    invoked from within
"set encodedVal [FME_EncodeText {Y:\\web_processing\\Projects\\Teranet\\postgis_clip
per\\parcel_tiles_2013_03\\parcels_1\\parcel174355474302013tera\\Label.shp}..."
Program Terminating
Translation FAILED.
  • Mar 18, 2013 10:30 PM UTC
Hi Travis,
you seem to be running FME 2009 here, are you sure that's your intention? I'm guessing you could get these kinds of strange errors if you were to run a newer workbench file with a very old version of FME.
Try specifying the complete path of fme.exe (remember to put double quotes around it if there are any spaces in it) and see what happens.
Example "c:/program files/fme2013/fme.exe" <the rest of your parameters here>
David
davideagle
Forum|alt.badge.img+21
  • Mar 18, 2013 10:42 PM UTC
Hi, is the workspace you written with a later build of FME than build 5658 as that's the engine you are calling. This can happen with command line running when you have more than 1 build of FME installed. Either specify the full path to the later build FME.exe or edit your PATH environment variable to give priority to the newest install of FME.
  • Mar 19, 2013 12:55 PM UTC
Thanks for your help the translation now works!
