FME 2020 Python feature.removeAttribute(attr)
  • Jun 30, 2020 2:55 PM UTC
  • 126 views
mferwerda1111
Participant
I have a pythoncaller, that runs the below python, this works OK in FME 2018, but fails in 2020.
ERROR |Python Exception <SyntaxError>: invalid syntax (<string>, line 11)
FATAL |Factory proxy not initialized
I have the python interpreter set to 3.6+
So the script works in 2020 if I tag out the last line, so has something changed with the feature.removeAttribute function ?
import fmeobjects
def removeNulls(feature):
attrsin = feature.getAttribute('SRC_ATTRS')
attrs = attrsin.split(',')
for attr in attrs:
val = feature.getAttribute(attr)
if val == 'VCP' :
feature.setAttribute('attname',attr)
if val <> 'VCP' :
  • Jun 30, 2020 3:06 PM UTC
Isn't the syntax error the if-clause val <> 'VCP'? It should be val != 'VCP' to be correct in Python 3. Seemingly, it works in Python 2 with "a" <> "b".
mferwerda1111
Participant
  • Participant
  • Jun 30, 2020 3:15 PM UTC
Yep, that is it, you can tell I am not up on python, really appreciate the
mferwerda1111
Participant
  • Participant
  • Jun 30, 2020 3:16 PM UTC
Yep, that was it, you can tell I am not up on python, really appreciate the help.
  • Jun 30, 2020 3:27 PM UTC
No problems! I didn't know you could write <> not equals-statements in Python 2, so we've both learned!
