FME 2020.0 error "No module named fmeobjects"
  • Mar 25, 2020 11:06 AM UTC
  • 14 replies
  • 281 views
koen
Forum|alt.badge.img+14
We recently installed FME 2020 we get the following error message when running workspaces with a Python Startup Script
Python Exception <ImportError>: No module named fmeobjects
Failed to import `fmesite'
System setup:
  • Microsoft Windows Server 2016 Standard
  • FME Desktop 2020.0 64-bit
  • ArcGIS Desktop 10.6.1
  • ArcGIS Desktop Background Geoprocessing 10.6.1 (64-bit) +
  • ArcGIS Desktop Background Geoprocessing patch for Oracle 19C
  • Oracle Client 19c
  • Oracle instant client 19.5 64-bit
Workspace settings:
  • Preferred Python Interpreter: Esri ArcGIS Python 2.7
  • Python Compatibility: Esri ArcGIS Python 2.7
The problem doesn't occur in our previous version (FME 2019.2.2) with the other settings the same, so it seems it only occurs with FME 2020.
Any idea how to fix this?
Best answer by itsmatt
I would say its because python 2.7 libraries for FME are no longer installed by default. Even if you are using a 2.7 interpreter and trying to use fme modules then you would need to have them installed.
If you must use Python 2.7 I would suggest reinstalling and check the box to install the 2.7 python libraries.
  • Mar 25, 2020 12:31 PM UTC
Check the environment variables, in particular that if you have PYTHONHOME defined, that it points to the 64-bit Python, e.g. C:\\Python27\\ArcGISx6410.6
koen
  • Mar 25, 2020 12:40 PM UTC
Already tried setting PYTHONHOME to C:\\Python27\\ArcGISx6410.6, but that didn't help.
With FME 2019.2.2 we didn't have the PYTHONHOME variable, and it worked fine.
Did anything in FME 2020 regarding python processing?
  • Mar 25, 2020 1:51 PM UTC
Is the PYTHONPATH environment variable defined on your system? If so, what is the value?
I do not know if something fundamental changed in FME 2020 regarding Python, you may have to contact Safe support for that.
If you feel like digging into it yourself, this is a very good resource that explains how imports and search paths work: https://www.devdungeon.com/content/python-import-syspath-and-pythonpath-tutorial#toc-13
koen
  • Mar 25, 2020 1:55 PM UTC
Tried PYTHONPATH=C:\\Python27\\ArcGISx6410.6 also
Didn't help
  • Mar 25, 2020 1:57 PM UTC
Didn't help
You may already know this, but I'll mention it just in case: whenever these environment variables are changed, at the very minimum FME needs to be restarted completely. I've also seen instances where a reboot was necessary.
My recommendation would be to set PYTHONHOME and to leave PYTHONPATH undefined (not set).
arnold_bijlsma
Forum|alt.badge.img+16
Since Python 2.7 is deprecated, it is only installed by choice. Could it be as simple as 2.7 not getting installed?
koen
  • Mar 25, 2020 3:28 PM UTC
Python 2.7 is installed by ArcGIS in C:\\Python27\\ArcGIS10.2
and the Python 2.7 64-bit is installed by ArcGIS Desktop Background Geoprocessing in C:\\Python27\\ArcGISx6410.2
arnold_bijlsma
But I could imagine you would need some 2.7 fme libraries as well, which I guess only get installed with FME Python 2.7.
But I am just second-guessing and may be talking nonsense....
itsmatt
Forum|alt.badge.img+48
  • Mar 25, 2020 4:12 PM UTC
itsmatt
Yes this seems right to me @arnold_bijlsma
  • Mar 25, 2020 4:16 PM UTC
Entirely agree as well.
itsmatt
  • Mar 25, 2020 4:17 PM UTC
You can see that the python27 libraries no longer exist by default in the FME 2020 install folder.
koen
  • Mar 25, 2020 5:20 PM UTC
Yes, that fixed the problem!
On my earlier install I didn't check the python 2.7 checkbox, since that wasn't necessary in previous versions.
Thanks a lot for all your quick answers.
koen
  • Mar 25, 2020 5:23 PM UTC
Yes, the problem was with the installation. I should have check the checkbox for installing Python 2.7
Though that wasn't necessary, because python 2.7 was already installed with ArcGIS and in previous versions that was enough.
Thank for your quick answers and replies.
