FME 2019: How can I re-run even if FME thinks all caches are up-to-date?
  • Apr 12, 2019 10:00 PM UTC
  • 86 views
Our jobs pull from APIs with ever changing results. The caches WILL change. But FME 2019 won't let me re-run with feature caching on thinking that the data will be the same. It won't.
Best answer by chrisatsafe
Hi @rfslivajr,
You can re-run the entire workspace from Menu > Run > Rerun Entire Workspace or using the keyboard shortcut Shift+F5.
Hope this helps!
chrisatsafe
  • Apr 12, 2019 10:17 PM UTC
Hi @rfslivajr,
Hope this helps!
