Finding matching text - grouped by attribute
Hi there, I thought this seemed simple but i've become a bit stuck:
I have x features (many millions but im running a testset of 20k) and they all have an Parcel number. Each feature has an associated Category (one of eight) that is made up of 1 to 3 letters.
Now, each parcel number does not necessarily occur just once; there could be up to 9 instances of each parcel number and each instance may, or may not, have the same Category code.
I wanted to test the Category attribute - grouped by Parcel - to see if there was a complete set of Category duplicates ('Yes') or if the Category differed at all ('No') for a given parcel.
(Bonus qu: In some cases where there are 6 instances of a Parcel and there are 3 different categories, it is clear to see that the 3 different categories have been duplicated by mistake - because there are associated identical areas - does anyone know how to clean those out??)
thanks all
Best answer by takashi
OK. I think this workflow would be one of ways to do that.
1) Aggregator_1 counts number of records for every identical ParcelID.
Group By: ParcelID
Mode: Attributes Only
Count Attributes: _num1
2) Sampler selects records having unique combination of ParcelID and Category.
Group By: ParcelID, Category
Sampling Type: First N Features
Sampling Amount: 1
3) Aggregator_2 counts number of the combinations for every identical ParcelID. If all the records of an identical PracelID has the same Category code, _num2 will be 1.
Group By: ParcelID
Count Attributes: _num2
4) FeatureMerger merges _num1 and _num2 to original records.
Join On: ParcelID
Feature Merge Type: Attribute Only
Process Duplicate Suppliers: Yes  *this is important
5) AttributeCreator creates "Duplicate" attribute. If _num1 is greater than 1 and also _num2 is equal to 1, set "yes". Otherwise set "no".
Attribute Name: Duplicate
Value: 2 Possible Values *use Conditional Value setting
If 1 < @Value(_num1) AND @Value(_num2) = 1  Then  yes
Else  no
  • March 9, 2014
The requirement and actual data condition is vague, but the Matcher might help you.
If you explain more concretely the condition using simplified example, we can think of more concrete solution.
Takashi
  • March 9, 2014
Sorry for any vagueness, here is a crude example of the data with only the relevant attributes filled in;
As you can see, some of the ParcelIDs are unique, that is fine, but some of them exist more than once and, for those that occur more than once, sometimes the Category code is the same across instances and sometimes it is different (ID 112 is the same but you can see 113's are not all the same - i am concerned where they are all the same).
I have put in a column saying 'duplicate' which is what im aiming to automate across many millions of features.
Actually I have come up with a very crude working using Listbuilder to extract Category grouped by ParcelID then AttributeCreator and a long series of testers and composite testers to see if categories match each other or not. There has to be an easier way as i've used about 12 transformers and still havent got it right!
  • March 9, 2014
I thought you are trying to find not-unique pair of Parcel ID and Category code. That is, expected result should be:
Unique:
111 CA
113 GP
114 F
Duplicated:
112 CP
113 GT ??
115 CP
But in your example, "113 GT" is not classified as "Duplicated".
Could you please define the condition where the pair of Parcel ID and Category should be decided as "Duplicated"?
  • March 9, 2014
Hi Takashi, no not duplicated pairs, I am looking for duplicates to be identified when all the parcels of a given ID have the same category. If one instance of a parcel ID has a different category to the others, then it is not duplicate.
  • March 10, 2014
Group By: ParcelID
Sampling Amount: 1
Group By: ParcelID
Join On: ParcelID
Else  no
  • March 10, 2014
The workflow can be replaces with an InlineQuerier.
SQL Query Example:
select *,
case
  when 1 < _num1 and _num2 = 1 then 'yes'
  else 'no'
end as Duplicate
from Parcel as a
inner join (select ParcelID, count(*) as _num1
  from Parcel group by ParcelID) as b
  on b.ParcelID = a.ParcelID
inner join (select ParcelID, count(*) as _num2
  from (select distinct ParcelID, Category from Parcel) group by ParcelID) as c
  on c.ParcelID = a.ParcelID
  • March 10, 2014
Thanks very much Takashi, i'll give it a go today
  • March 10, 2014
At first inspection the workflow works correctly, thank you very much indeed. S.
