Find the Nearest Neighbour
  • February 10, 2025
  • 18 views
2eight
Hello there,
i want to mark some points which are already placed at each corner of the building polygons in a DGN(MicroStation) file,
i want to mark points which exist within 10m buffer from the road, and also points which at the road facing side of the building not at the back side of the building polygons,
when i tried using the buffer it covered all the points including the backside points, if buffer reduced some building points got missed
seen the image, the intention is to mark only the blue circled points
looking for some suggestion, ideas are most welcome
thanks.
crutledge
Forum|alt.badge.img+33
  • February 10, 2025
I have used the nieghborfinder to do something similar. This will work better than a buffer. You would be able to then get a list of distances from each building and then sort and select the top (closest ones) Hope that helps.
