Filter out or delete list values
I have a polygon layer with x,y,z coordinates.
For each polygon, I would like to calculate the mean z-value. For this I use the ListStatisticsCalculator, which works perfectly.
The problem is, that some polygons consists of one or more useless z-value (-999, -9999 etc.). I would like to filter out these values (or delete them) before running it through the ListStatisticsCalculator.
I have tried the ListElementFilter with Filter Type Numeric Range, but I can't get it to work properly.
Any thoughts?
Thanks,
Stig
Best answer by david_r
How have you configured the ListElementFilter? This example works for me, removing all list values outside the range 0-99. Notice the paranthesis around the match expression, otherwise it won't work as expected:
Forum|alt.badge.img+49
The easiest and most elegant way (in terms of Best Practices) would be to remove those values before building the list. A Tester or TestFilter can be used for that.
  • May 2, 2018
  • May 2, 2018
Wouldn't I need to extract the coordinates before doing that? The way I do it now, is to create lists with all coordinates in the CoordinateExtractor.
How do I remove z-values with the Tester, if there is no attribute containing all z-values?
  • May 2, 2018
I thought I had configured it the right way, but I forgot the parenthesis. Doh!
I works perfectly now. Thanks.
