filter files in folder based on input
  • May 21, 2018 12:46 PM UTC
  • 157 views
Hello,
I have as an input parameter a list of ids separated by "|".
For example: 1|2|4
Next I have a directory with some zip files:
1.zip, 2.zip, 3,zip., 4,zip, 5,zip
As a result I would like to get only files which have names that are in the input list and have it all zipped to the result.zip file:
result.zip
|_1.zip
|_2.zip
|_4.zip
I came to the point where I used attribute splitter and I have a list of those Ids but I have no idea what to do next. Can you please help me with that?
Thanks!
erik_jan
Forum|alt.badge.img+26
  • May 21, 2018 1:53 PM UTC
I would take this approach:
Unpack parameter: AttributeSplitter
Create features from list: ListExploder
Create filenames: StringConcatenator
Copy files to different location: SystemCaller (Copy command).
Zip files: SystemCaller (Zip command).
Hope this helps.
  • May 21, 2018 1:54 PM UTC
Hi @witos, the Directory and File Pathnames (PATH) reader and the File Copy writer might help you. For example, assuming the filter string (pipe-separated target file names) is given via a user parameter called "FILTER":
See these links to learn about the Path Filter parameter configuration.
