Filter feature classes by editor tracking field
  • Jul 10, 2019 5:55 PM UTC
  • 70 views
Hi all,
Context: I have a workbench that is aggregating and compiling data from 13 different SDEs. The datasets are managed slightly different source-by-source. I determine adds, updates and deletes via a CRC comparison, but there are feature classes (not all, some) that are participating in editor tracking. There are two different possibilities for the pertinent editor tracking field: MODIFY_DATE and last_edited_date. Sometimes, both of these fields exist in a feature class, with one being associated to esri's editor tracking.
Objective: I want to use the arcpy method, describe, to pull the editor tracking field name. Based on that result, I want to filter features on 1) if they have editor tracking enabled, then 2) between MODIFY_DATE and last_edited_date.
Method: I have a private parameter python (named editorTracking) script as follows:
import fme
import fmeobjects
import arcpy
def processFeature(feature):
    desc = arcpy.Describe(feature.getAttribute(pathway))
    if desc.editorTrackingEnabled:
        if desc.editedAtFieldName == "MODIFY_DATE":
            return "1"
        elif desc.editedAtFieldName == "last_edited_date":
            return "2"
Variable 'pathway' is assigned earlier in the workbench. It's the absolute path to the feature class, required for the Describe method. I have a test filter that is set with two outputs: 1) if editorTracking (private parameter python script) = 1 2) if editorTracking = 2
I am not getting any type of filtering through this method. I do not know if the test filter and a private parameter python script operate together in this manner. Does anyone have some feedback on my methodology here?
Thanks.
daveatsafe
Forum|alt.badge.img+24
  • Jul 16, 2019 4:49 PM UTC
Hi @cwchumley,
You have a typo in the second line, which will disable fmeobjects.
  • Jul 17, 2019 8:00 PM UTC
Hi @cwchumley,
Hey Dave,
Thanks for the heads up. I manually wrote the code in (couldn't get the formatting to work out when copy/pasting) and that typo was only here. I'll edit my original post. Thanks for pointing that out!
