Filling newly created attribute with existing attribute?
  • Apr 20, 2016 9:42 PM UTC
  • 5 replies
  • 138 views
So we have an issue where the ID is being used also as the Object ID. This of course is a big problem because any database or GIS software will overwrite the ID. So to get around this I want to create an attribute in FME and then fill that with the Object ID values to preserve that number. I can create new attributes with the attribute creator but I can't find any examples or forum topics on how to call out an attribute value to fill it with. I've only seen constants or using this empty column later.
Best answer by ryanatsafe
Sounds like a job for the AttributeCopier
ryanatsafe
Forum|alt.badge.img+11
  • Apr 20, 2016 9:45 PM UTC
  • Apr 20, 2016 9:52 PM UTC
Ooo! Exactly what I needed! Just one question though, is it creating a NEW colum for me or do I still need to use the Creator first then this?
ryanatsafe
  • Apr 20, 2016 10:31 PM UTC
The AttributeCopier will create the new column for you.
  • Apr 20, 2016 10:39 PM UTC
Thanks! That does the job!
Forum|alt.badge.img+54
  • Apr 21, 2016 8:16 AM UTC
Is there any difference between this and just using an AttributeCreator?
