Fill attribute values but not for all the records
  • Jun 23, 2020 7:20 AM UTC
  • 7 replies
  • 55 views
Hi. I have two datasets. One of them has 25562 records. The other one has 16310 and it contains the values for an attribute that I want to put in the larger dataset. I have tried with AttibuteMerger and Attribute Joiner, but the result is a dataset with only the 16310 records that both datasets share. How can I fill de 16310 records and keep the rest empty on the larger dataset? Thanks!
Forum|alt.badge.img+54
  • Jun 23, 2020 7:29 AM UTC
Just join up the unmerged requestor port back into your workflow
You could also use a FeatureJoiner instead and use a Left Join to return all the records from one dataset whether matched or not
The output port UnmergedRequestor will contain the remaining requestor features that did not find a match in the supplier dataset.
becchr
Forum|alt.badge.img+35
hi @juanrodriguezso, the other records are in the 'unmergedRequestor' port, no?
you can get them from there
As simple as that! :) Thank you all!
So easy... :) Thanks!
So easy.... :) Thanks!!!
So easy... _) thanks!
