FeatureWriter number of features written incorrect?
  • Nov 30, 2017 2:04 AM UTC
  • 6 replies
  • 166 views
ekkischeffler
Forum|alt.badge.img+7
I'm using a FeatureWriter with its output attribute "_total_features_written". The attribute holds "_total_features_written"=1 while the log says:
Features Written
Total Features Written 0
Features With No Schema defined
NoFeaturesTester_5_Creator 1
Total Features NOT Written 1
Has anyone experienced this before? Seems like a bug. This is using FME 2017 build 17259.
  • Nov 30, 2017 2:12 AM UTC
Hi @ekkischeffler, yes, it's a known issue, and has been discussed here.
How to count FeatureWriter transformer's output into "Feature Written Summary" of the log?
We have to wait for a relevant enhancement.
ekkischeffler
  • Nov 30, 2017 2:33 AM UTC
Thanks for referencing this Takashi. In my case, however, the writer did indeed write nothing while the attribute contained '1'. So, I think the attribute value is incorrect rather than the log.
  • Nov 30, 2017 2:47 AM UTC
I was able to reproduce that. I think it's also an issue that should be improved.
featurewriter-total-features-written.fmw (FME 2017.1.1.1)
Could you please check this? @daleatsafe
  • Total Features Written = 0
  • Total Features NOT Written = 1
  • _total_features_written (Summary feature) = 1 (incorrect)
                               Features Written
Creator        1
Storing feature(s) to FME feature store file `.\mapping_log.ffs'
FeatureWriter_Summary: Feature is:
Feature Type: `FeatureWriter_Summary_LOGGED'
Attribute(string)                 : `_dataset' has value `C:\FME\tmp'
Attribute(32 bit unsigned integer): `_feature_type{0}.count' has value `1'
Attribute(string)                 : `_feature_type{0}.name' has value `Creator'
Attribute(32 bit unsigned integer): `_total_features_written' has value `1'
Attribute(string)                 : `fme_geometry' has value `fme_undefined'
Attribute(string)                 : `fme_type' has value `fme_no_geom'
Geometry Type: Unknown (0)
ekkischeffler
  • Nov 30, 2017 3:02 AM UTC
                               Features Written
Creator        1
Thanks for clarifying, Takashi!
                               Features Written
Creator        1
Hi @takashi and @ekkischeffler,
I'm sorry that you have run into this issue. This is an issue that is currently being investigated by development; I will be sure to update this thread once the fix has been released.
Kind Regards,
Annabelle
  • Dec 10, 2019 3:52 PM UTC
                               Features Written
Creator        1
@annabelleatsafe any update on this? I'm currently working on v2019.0.2 and I'm facing the same issue in both FME Desktop and FME Server.
