FeatureWriter attributes settings not holding
  • Nov 5, 2019 2:58 AM UTC
  • 50 views
deanhowell
Forum|alt.badge.img+24
Hello FME Support,
I am running FME Desktop Version 2019.1 and have found that the user attribute settings are not holding after being changed in the FeatureWriter.
I have an attribute called "category" which was using the conditional option to set one of two options.
I wanted to add another option that had multiple parts
First thing was that I had to type the 'AND' as it wouldn't select from the list and secondly it did not save once I pressed OK.
deanhowell
  • Nov 5, 2019 3:32 AM UTC
I managed to undertake a work-around by using the AttributeCreator but not sure why it is not working in the FeatureWriter
