Features get written to the wrong level.
  • Feb 14, 2019 3:09 PM UTC
  • 35 views
mmbarabas
Participant
I have a Microstation v8 file that has 60 odd levels from which I have to filter out 20 and further filter those 20 levels to based on the color of the features. One level has features that go on two different output levels. I am using an Attributefilter to filter them out based on their color value, then use several FeatureCreators to write out the features with the destination color, weight to the destination levels. When I look at the log it shows that features were created for two destination levels, but when I open the dgn file I see no features on one of the destination levels. All output features will be written on a single level. Any idea why?
itay
Forum|alt.badge.img+19
  • Feb 14, 2019 7:24 PM UTC
Hi @mmbarabas,
Are you using a writer feature type fanout? and are you sure they have different values? this should create separate levels in the output DGN.
Hope this helps,
Itay
