FeatureReader resets PostGIS schema to my saved default.
  • Oct 3, 2017 12:31 PM UTC
  • 43 views
nielsgerrits
Forum|alt.badge.img+67
Windows 7 / FME Desktop 2017.1.0.0 build 17539
FeatureReader with PostGIS.
In the FeatureReader, in the (PostGIS) Parameters, in Schemas for Table Listing, the schema "data" is saved as my default. Works like a dream.
Every now and then I need to edit a workbench with another schema already configured. Now it comes: when I open the FeatureReader to edit the Feature Types to Read, I get Failed to retrieve feature types. I believe my default PostGIS schema setting is overriding the original configured schema.
I wonder if this is how it should work.
nielsgerrits
This is fixed in 2017.1.1.
