FeatureReader fails when feature caching is enable
  • Jan 25, 2019 3:45 AM UTC
  • 73 views
rudy_v
Hi All,
I have a Feature Reader, using an excel file, it work perfect, but when i enable feature caching it fails on the feature reader
i don't know if this is a bug?
@rudy_v I couldn't reproduce the error. Perhaps you could include an example workspace, data and let us know the build number of FME you're using. A short movie of the steps you use to generate the error sometimes helps. If the data is sensitive then please open a support case through https://www.safe.com/support/report-a-problem/
sigtill
Forum|alt.badge.img+25
  • Nov 14, 2019 12:20 PM UTC
Hi @rudy_v - did you by any chance leave the workspace open and return the next day, continuing the next day? I have experienced similar things when the workspace is open for too long (seems to be some caching related).
