FeatureMerger with conditional parameters
  • Jan 28, 2015 4:31 PM UTC
  • 52 views
I would like to know if it is possible use conditional value for the requestor and supplier in a FeatureMerger in order to achieve something like this:
IF Requestor's Attribute_A = 'some_value'
    JOIN Requestor's Attribute_A WITH Supplier's Attribute_A
ELSE
    JOIN Requestor's Attribute_B WITH Supplier'S Attribute_B
I have made many tryes, but it seems we cannot change the Supplier join attribute in function of the Requestor's attribute value.
gio
Forum|alt.badge.img+15
  • Jan 28, 2015 5:39 PM UTC
The conditional relating is just a preselector of data to be related form suplier as wel as requestor based on a chosen attribute.
Attribute cannot be changed conditionally, only its value chosen.
  • Jan 28, 2015 5:45 PM UTC
Hi Burton,
How about simply using two FeatureMergers? i.e. one for features that have "some_vaue" as Attribute_A, another for others.
You can branch the flow of requestor features into two streams by the Tester.
Takashi
  • Jan 28, 2015 7:04 PM UTC
Ok thank you, actually I was asking that question to use one featureMerger instead of two. But anyway I dont think there would be a gain in speed...
