Feature Writer with CSV and >100 files?
  • Jun 23, 2020 9:30 AM UTC
  • 146 views
I am trying to split a very large csv-file for further processing. I currently read the input, count the features, divide by a set number of max lines, round to integer and use this attribute as a filename to write new files with a feature writer.
Somehow, the attribute is calculated correctly but using it as a filename results in a maximum number of 100 files being written. The feature writer then starts overwriting the first file again.
Am I missing something?
  • Jun 23, 2020 9:37 AM UTC
There are several possible solutions, but the easiest is perhaps to simply use the GroupCounter from the FME Hub: https://hub.safe.com/publishers/lars-de-vries/transformers/groupcounter
You can then use the resulting attribute _group for the fanout.
  • Jun 23, 2020 9:47 AM UTC
The attribute is calculated correctly. Only the fanout doesn't work within the featurewriter.
  • Jun 23, 2020 9:57 AM UTC
That is surprising and unexpected. Can you show us some screenshots of how the fanout is configured? And have you double-checked that the fanout value is indeed correct for values > 99?
