Feature Reader in FME form 2023.1
  • Oct 2, 2023 6:57 PM UTC
  • 195 views
fme_can_do_it
Forum|alt.badge.img+13
I am having issues using Feature Reader to access ArcSDE geodatabase in FME Form 2023.1. When opening the Feature reader in the old FME version, there is a DataSet option to select after choosing the Format. I also have the option to create connection files as a user parameter. Now in FME Form 2023.1, After selecting Format, the Dataset option changed to Connection. However, when I try to select a new connection file within the parameters, I am unable to find the option. In my previous FME workspace, I utilized connection files as user parameters. Please let me know if I am missing anything while configuring the Feature reader to read ArcSDE data in FME Form 2023.1. Thank you!
hkingsbury
Forum|alt.badge.img+73
  • Oct 2, 2023 7:07 PM UTC
I think whats changed (and hasn't really been that well documented or conveyed - that I've noticed) is that SDE connections are now a DatabaseConnection. So you don't reference a file, instead you create a connection and reference that instead of directly referencing the connection file.imageSo you can still use parameters, its just that now the parameter type will be a database connection (when it used to be a file)
 @mark2atsafe​
fme_can_do_it
  • Oct 3, 2023 3:31 PM UTC
 @mark2atsafe​
@hkingsbury When working with my workspace, I require referencing multiple SDE connections. I have set these SDE connection files as User parameters so that they can be changed when needed. Is there a way I can accomplish the same thing in the newer version of FME reader as referencing database connection only won't be helpful in my case?
hkingsbury
  • Oct 3, 2023 6:54 PM UTC
You'd have to set them all up as Database Connections, but then you can reference them in parameters as a "database connection". Make sure you set the type as "Esri ArcSDE Geodatabase"
