I’m trying to identify the vertex/vertices in a 3D dataset which are at the zmin.
The task is very easy but I’m trying to figure out the fastest/cleanest way to do this. The dataset could be quite big and the geometry could be any type (not point cloud or raster).
Fastest was to extract vertex with zmin?
Best answer by ebygomm
If you don’t want to go down the python route, then I would think that getting the vertices as a list, using a list range extractor to find the min z and then a listsearcher to find that coordinate would be more efficient than chopping to points?
