Exposing FME attributes - fme_coordinate_system
  • Nov 4, 2013 11:11 PM UTC
  • 105 views
Hi FMEers
Hopefully this is an easy question for someone to answer.
I've got a workbench that dynamically reads WFS and output a selected feature type to a file geodatabase.  I'd like to extract some fme attributes from the input data (such as fme_coordinate_system).  I know that you can use the attribute exposer transformer or expose some of the fme attributes in the the reader but I can't figure out how to get the coordinate system (not set at runtime - read from WFS by the reader) into an attribute.
Does anyone know how to do this?
Thanks
Rob
Best answer by david_r
have you tried using a CoordinateSystemExtractor?
David
  • Nov 5, 2013 7:57 AM UTC
David
  • Nov 5, 2013 10:31 PM UTC
Ahhh, obvious!
Thanks very much David.
