Esri conversion polygonz (3D) to polygon (2D)
  • September 13, 2016
  • 6 replies
  • 40 views
akeeri
Forum|alt.badge.img+3
Is there a way to automatically remove the third dimension
I have an old program that I use sometimes and after conversions from dwg to .shp andafter that I still have to use an avenue-macro to continue the conversion to an 2d shapefile
Best answer by mark2atsafe
The Shape feature type properties dialog has a setting for geometry type.
I thnk we automatically set this according to the data being written. So - as others have said - the 2DForcer would be the way to go. Then your data is 2D and the file is 2D.
But: Prior to 2016 there were separate options for shape_polygon and shape_polygonz. I expect shape_polygonz would write a 3D file, even if the data was forced to 2D.
So, if you are using 2015 or earlier, make sure to open the feature type dialogs and change from polygonz to polygon as well.
Forum|alt.badge.img+34
Take a look at the 2dforcer transformer
itay
Forum|alt.badge.img+17
2DForcer is What you need
mark2atsafe
Forum|alt.badge.img+44
akeeri
  • September 14, 2016
Thanks I am still on 2013
Can you explain more, I have found an option in the writers-dialog in Workbench
Shape File Type(2D (ArcView 3.0), 2D + Measures, 3D + Measures)
Is that the option you are meaning or where?
thanks in advance
mark2atsafe
thanks in advance
No, you'll find it by clicking the button on the Shape objects in the canvas. Here's a quick video (in FME2015) showing where to find this: http://screencast.com/t/UAplkRPSy
akeeri
  • September 22, 2016
Thanks i got it
