Enterprise Geodatabase metadata
  • Jul 16, 2014 5:27 PM UTC
  • 55 views
Is there a way to read metadata in an Enterprise Geodatabase?  I see that you can do it with geodatabases (http://docs.safe.com/fme/2013/html/FME_ReadersWriters/Default.htm#geodatabase/FEATURE_READ_MODE.htm) but I dont see that option in enterprise gdb.
Thanks
  • Jul 17, 2014 10:15 AM UTC
There is no such thing as an "Enterprise Geodatabase" reader in FME 2013, as far as I can tell. Are you thinking of the "Esri Geodatabase (ArcSDE Geodatabase)" reader?
It should be able to read metadata using the "geodb_metadata_string" format parameter when setting the feature read mode to "Metadata" on the reader.
See also this free recorded webinar for more info:
http://www.safe.com/webinars/mastering-geospatial-metadata-with-fme/
David
  • Aug 19, 2014 9:46 PM UTC
Thank you David.
I see that they mention that it can be done but don't show how to do this.  There are many examples of reading xml from a file (super!) but when reading from a geodatabase using the Metadata parameter it gets lumped into one attribute.  Do you konw how I can explode that xml?  I've played around with all of the xml transformers like flattener, fragmenter and feature mapper but they did not work for me.
Cheers
  • Aug 20, 2014 6:39 AM UTC
you can use the XMLFragmenter to split up an attribute containing an XML document into separate features, just like the XML reader. The settings and options are identical.
David
