Engine control by FME Console command parameter
  • Feb 5, 2013 9:16 AM UTC
  • 6 replies
  • 99 views
frantsch
Forum|alt.badge.img+5
We have more than one FME Engine installed on our FME Server host. The Engines have different Versions, e.g. one Engine is 2012 and one 2013. This is inevitable in order to keep older workbenches functioning due to a lacking downward compatibility.
So far with FME 2012 Server I was able to define on which of the engines a service will be run by assigning a parameter such as 'tm_fmeInstance Engine1' on the FME Server Console command (line).
With FME 2013 Server this does no loger work. How am I to control the engine on which a service will be executed?
Best answer by mark_f
Does this help?
http://docs.safe.com/fme/2013/html/FME_Server_AdminGuide/Content/AdminGuide/High_Avail_Install/Configure_Job_Routing.htm
frantsch
  • Feb 5, 2013 9:29 AM UTC
Found a possible answer to the above issue myself:
http://fmepedia.safe.com/articles/How_To/Assigning-jobs-to-a-subset-of-available-FME-Engines
We obviously neet to do some configuration work on our upgraded FME Server...
frantsch
  • Feb 5, 2013 9:39 AM UTC
frantsch
  • Feb 5, 2013 11:54 AM UTC
Well, the two answers above and the given links are valid for SME 2012 Server only. The solution for FME 2013 Server is still needed.
  • Feb 5, 2013 2:19 PM UTC
  • Mar 27, 2013 11:07 AM UTC
  • Mar 27, 2013 11:21 AM UTC
Diagram showing Server Engines Tagged
