Enable/disable transformer/connection with user parameter?
  • Mar 10, 2015 6:54 AM UTC
  • 128 views
Forum|alt.badge.img+3
Is it possible to enable/disable a transformer or a connection in a workspace using a published parameter?
  • Mar 10, 2015 7:27 AM UTC
I don't think it's possible. But you can use the Tester or the TestFilter to control data flow depending on a parameter value.
Takashi
Thanks for the tip! I'll try that instead.
Turid
