Dynamic writer not able to write to arcgis dataset
  • Feb 27, 2018 6:35 PM UTC
  • 100 views
I'm trying to Dynamic writer to a dataset within an arcgis gdb. I set my fme_feature_type to dataset/fuse but it will create a fc at the root directory named dataset_fuse. I then discovered there is a "feature Dataset" field to fill in ...and i did with dataset
Then it does create a file named dataset_fuse within the dataset. But it doesn't use my schema.
if i alter my fme_feature_type to just fuse then it says it can't find the schema and doesn't write.
this is my gdb setup:
arcgis.fgdb
dataset
fuse
thank you
  • Feb 28, 2018 5:01 AM UTC
Hi @avineon, "fme_feature_type" stores the source feature type name and FME will treat it as a Schema Definition Name (identifier of the schema configuration in the source feature type). You therefore should not modify the value of "fme_feature_type", if you intend to configure the destination schema according to the source schema dynamically.
If your requirements were:
  • write the features into a destination feature class named "dataset_fuse",
  • apply the schema derived from the source feature type to the "dataset_fuse" class,
try configuring the dynamic writer feature type as below. Here, assuming that the source dataset contains only a single feature type. Do not change the value of "fme_feature_type" which is retrieved from the source dataset.
  • Feb 28, 2018 5:16 AM UTC
If you want to create a new "Feature Dataset" named "dataset", set another parameter in the writer feature type, like this.
Note: You have to use GEODATABASE_FILE writer to create a new feature dataset. The FILEGDB (File Geodb Open API) writer doesn't seem to support creating feature dataset.
