Dynamic Workspace Parameter fails after upgrading FME Flow from 2025.2 to 2026.2
  • Jul 28, 2026 12:01 PM UTC
  • 76 views
felix.pekarek
Hi everyone,
After upgrading our FME Flow instance from 2025.2 to 2026.2, a workspace parameter with dynamic values stopped working in a Workspace App.
When opening the app, FME Flow shows the following error when testing the dynamic parameters:
Loading from Workspace
Kartenautomatisierungen/Kartenautomatisierung_ZUBA_PreScript_2.fmw
Error loading schema
Unable to generate dynamic parameters from source file.
Error was:
E:\appdata\fme\systemshare\resources\system\null\null\FeatureWriter\ZUBA.json
Please ensure the file exists and is readable.
A few observations:
  • The same setup worked without issues in FME Flow 2025.2.
  • The workspace itself executes successfully. It loads the JSON after the workspace is done.
  • The error only occurs while loading the dynamic workspace parameter.
  • The path contains system\null\null\FeatureWriter\ZUBA.json, and the corresponding folders do not exist.
  • I never configured FME to write schema files to that location.
Has anyone seen a similar issue after upgrading to 2026.2? Is this a known problem with dynamic workspace parameters or FeatureWriter based schema generation?
There is a known issue (FMEFLOW-27717) regarding this, which should be resolved in 2026.2 but I still get this error.
hkingsbury
Forum|alt.badge.img+73
  • Jul 29, 2026 2:34 AM UTC
I wonder if there may be a slight change in the backend of dynamic parameters between the two versions that's causing this issue.
If you make a new workspace app (or maybe just recreate the dynamic parameter in the existing app) does that resolve it?
felix.pekarek
  • Jul 29, 2026 7:22 AM UTC
I already tried that as well because I had the same suspicion. Unfortunately, it did not resolve the issue.
I tested both duplicating the workspace and creating a completely new workspace from scratch, but neither approach helped. I also removed all existing published workspaces from FME Flow and uploaded them again, however the problem persists.
felix.pekarek
  • Jul 31, 2026 9:01 AM UTC
The issue was resolved after reinstalling FME Flow. It looks like the original deployment by me may have been faulty. Thanks for your help and suggestions! 😊
