Dynamic Schema - Help
  • Jun 17, 2014 1:02 PM UTC
  • 87 views
I am using FME Desktop 2013, Build 13448 to try and complete the following workflow.
Read in CSV's from a directory; as these have have differing numbers and names for attribute fields, before I complete the required processing. NOTE that all input files will have the 3 required I need even if they are named differently (extra fields can be ignored). I had planned to create a lookup.csv to manage the mappings and then use the schema mapper to read in the Survey CSV and the lookup csv and then create an output with only the 3 required fields with the new names. However, I must be doing something wrong as it is not working as imagined.
Input Survey examples:
File1 Schema
EAST,NORTH,HEIGHT
File2 Schema
easting,hei,Nothing,date,time
File3 Schema
X,Y,Z,Time
Lookup,csv
old,new
EAST,NEW_EASTING
easting,NEW_EASTING
X,NEW_EASTING
NORTH,NEW_NORTHING
Northing,NEW_NORTHING
Y,NEW_NORTHING
HEIGHT,NEW_HEIGHT
hei,NEW_HEIGHT
Z,NEW_HEIGHT
expected output
NEW_EASTING,NEW_NORTHING,NEW_HEIGHT
date, time and Time entries would be discarded.
I created the following
1. I have created my lookup table.csv containing field mappings
2. I have configured a CSV reader to read in survey files from a directory, identical schemas set to NO (single merged type)
3. I have hooked up a SchemaMapper straight after the CSV directory reader, I have also pointed it to the lookup csv. In the create actions dialog I have added an attribute map rule, source attribute field (old), destination attribute field (new)
However, the mapped output port does not rename the fields or remove the non required fields. Instead I have an additional _schemamapper_row_ids field populated with 1,2,3,.etc. based on the rows checked.
I have tried changing the additional options in the Attribute Map dialog e.g. default field value and source attribute keep/remove, but to no avail.
Have missed something obvious, if so what?
Looking online there appear to be various version of SchemaMapper with differing setups the one I am using is not the most current.
Regards,
Rob
gio
Forum|alt.badge.img+15
  • Jun 17, 2014 2:37 PM UTC
Your lookup uses duplicate mappings.
If u use attribute map, only the last gets mapped appearently. Yu can check this in the result with the _schemamapper_row_ids field.
I dont see any option to do "EAST" or "easting" or "X" Then "NEW_EASTING" (though i would expect a filter would/should be able to do that....)
I you use "new attribute" instead of "attribute map" with a tabel with no values, you get a table with the mappings.
Then u can use a attribute exploder so you have _att_name and _att_value. Where att_value contains the new attribute name.
(..or i am missing something too...;))
  • Jun 18, 2014 11:07 AM UTC
Hi Gio,
Thanks for the advice, I will give your method a try.
The Schema Mapper help was not overly clear, I presumed that because you could map many to 1 FeatureType names that  you would also be able to do the same with field headers.
Thanks again,
Rob
gio
  • Jun 18, 2014 2:19 PM UTC
Hi Rob,
Actually i assumed the same as you did.
I spent some minutes before i understood why it did'nt work.
