Dynamic schema definition for importing files
  • Jun 3, 2025 9:01 AM UTC
  • 119 views
theandroidbell
Forum|alt.badge.img+3
I want to run a batch process to load a series of file-based datasets in a folder, do some simple transformations and export each to a database table.  The workspace in the image below is run by a workspace runner.  The complication is that each source has some standard columns and an unknown quantity of additional columns, which need to be loaded into the database as a new table.  If I configure the workspace with one source file, the schema config will not be correct for another file.  How can I set the schema definition to be dynamic?  I’ve been researching the subject but have not found the answer.
  • Jun 3, 2025 11:45 AM UTC
Hi ​@theandroidbell ,
Have you learned "Tutorial: Dynamic Workflows"?
There are some ways to configure dynamic schema, but I think "Destination Schema as a Mirror Image of the Source Dataset" could be applied to your case.
nielsgerrits
Forum|alt.badge.img+67
