Dynamic reader/dynamic writer does this work for legacy sde in FME 2018?
  • Oct 18, 2018 6:43 AM UTC
  • 63 views
Does dynamic reader and dynamic writer works for legacy sde in FME 2018?
Best answer by rahulsharma
Hi @azajarc, you should be able to use both Reade and Writer in Dynamic setting.
NOTE: SDE30 Dynamic writer will require a careful structured workflow with regards to bounds of data in order to avoid errors.
rahulsharma
Forum|alt.badge.img+12
  • Oct 18, 2018 7:50 PM UTC
Also, please bear in mind Legacy ArcSDE reader & writer have been deprecated in newer versions of FME. See the article Esri Legacy ArcSDE . If you are using an older version of FME and ArcGIS then dynamic reader and writer should work with the FME ArcSDE Legacy reader & writer.
