Dynamic PDF generation
  • Jun 14, 2015 7:38 PM UTC
  • 0 replies
  • 47 views
jochgem
Hello!
For the following problem I used FME 2015.1.
For an assignment regarding automatic map generation data is read and clipped according to certain map boxes, after which they should be written away, per map box, to PDF-files. I use for that purpose a User Parameter, set to Choice (Multiple), such that the map boxes can be selected for printing.
If I check the writer, the layers need to be named according to a certain attribute, while the PDF-files should be named after the name of their map box.
Until now I was not successful doing that. I could set the pathname and the file name according to [PATHNAME\\$(Name_of_the_User_Parameter).pdf . If I would do that for a User Parameter, the Choice (Multiple) type, the name would be the full list that is selected as map box, and not written away individually.
Does anyone have a solution for this problem?
Kind regards,
Jochgem
