does fme supports VM ?
  • Sep 30, 2016 7:56 AM UTC
  • 145 views
Wanted to move from Physical to VM windows can FME supports? don't want to go for floating licenses as we are sure that only one user going to use
Best answer by david_r
FME Desktop works perfectly on virtual machines.
See also here: https://www.safe.com/fme/fme-desktop/tech-specs/
  • Sep 30, 2016 8:00 AM UTC
  • Sep 30, 2016 10:04 AM UTC
I second david_r reply.
We have been working with FME for the past year in a Windows Server 2012 VM with no problems.
FME versions 2015, 2016
mark2atsafe
Forum|alt.badge.img+59
We run all our FME training courses on Amazon virtual machines without much problem (where there are issues, it is usually the student's IT department blocking the port number they need to connect).
Also all our automated product testing occurs on virtual machines and we have lots of VMs set up for the support team so they can try FME using a customer's exact setup.
So we at Safe use them a lot and no problems occur.
