Directory and File Pathnames - Path Filter now case sensitive?
  • November 1, 2024
  • 99 views
Forum|alt.badge.img+31
In 2024.1 it appears that a Directory and File Pathnames reader with a Path Filter set to *.tab only reads tab files with a lowercase extension.
In 2021.2 both .tab and .TAB files are read
A MapInfo TAB file reader pointing at a folder path such as "E:\Mapinfo\**\*.tab" still reads both .TAB and .tab files
Is this expected behaviour?
tomfriedl
Forum|alt.badge.img+13
  • November 5, 2024
There is a break in 2024. 2023.2 work correct. I think it’s a bug, because Windows isn’t case sensitive.
  • November 5, 2024
I thought it was going to be straightforward to amend the directory and filenames reader for case insensitive matching but now i’m not so sure. I’ve reported to Safe
  • November 6, 2024
Raised as FMEENGINE-84597
DanAtSafe
Forum|alt.badge.img+16
FYI, FMEENGINE-84597 was fixed for FME 2025.0
