Deployment parameter - Local value doesn't work
sam_appleton
Forum|alt.badge.img+7
I have a deployment parameter (Text) that is pointing to an SDE file on FME flow in my shared resources. When I try to set a local value in form, it ignores this value and throws an error saying it can’t access the share resources file path. I’ve tried creating a deployment parameter that is  type: database connection, but this doesn’t work either. Here’s the error:
This was working a week ago and now it refuses to acknowledge the local value.
Many thanks,
Sam
Best answer by sam_appleton
Hi @david_r ,
I was using a text value that was pointing to the location of an SDE file. A fix for this was creating a deployment parameter of type ‘database connection’ which allowed me to use a local value.
IT seems FME form didn’t let me use a local value of type “text” to point at database files
  • July 8, 2024
In the error message it looks like a path relative to the root of your file system. Is this really correct? Does the folder “/SDE_Files” and all subfolders exist?
sam_appleton
  • July 8, 2024
Hi @david_r my local value that I set is DEV SDEFILE .The FME Flow value is $(FME_SHAREDRESOURCE_DATA)/SDE_Files/GISICOMSQLDV_YWSEWER_USER.sde . I assume flow is trying to read this in, and it;s dropping the shared resources part as it’s enclosed in brackets. Either way, it’s completely ignoring my local value that i’ve set
  • July 8, 2024
Interesting, perhaps FME Flow can’t resolve other macros in the context of deployment parameters? Sounds like a question for Safe support.
sam_appleton
  • September 2, 2024
Hi @david_r ,
