Data Interoperabilty Extension keeps stalling
  • Sep 4, 2026 5:08 PM UTC
  • 47 views
compasscarto
Forum|alt.badge.img+4
I have ArcGIS Pro Data Interoperability Extension.  Within the last couple of days, it keeps stalling at the start screen “Checking License”.  I know I have a license!  And it works sometimes…without any trouble.  If I Restart my PC, it opens fine, but if I try to run a reader (excel, csv), that is stalling as well.  Even though these are small files, they just don’t come in.  I’ve tried starting/stopping/pausing/purging, etc.  The only thing I’ve been able to do to get the Extension to open again, is to do a cold boot of the laptop.
Is there some other cache somewhere I need to clear out?  (I’ve cleared the cache from within FME Form itself) several times, but then end up rebooting anyway.
I’m relatively new to using FME, but these files are quite simple with only a couple thousand records.  I tried to read both as .xlsx and .csv today.  Could this be an issue with a log file filling up?
Thanks for any tips/suggestions.
veronikaatsafe
Forum|alt.badge.img+13
Hi ​@compasscarto ,
To look into this issue further, are you able to provide some additional information?
- What ArcGIS license is your organization using? Single-Use or Named-User or Concurrent Use?
- What ArcGIS Pro version are you on?
- If it is a Named-User license, is the license served from ArcGIS Online or ArcGIS Enterprise Portal?
- If the license is served from ArcGIS Enterprise, what is the Enterprise version?
Thank you!
