Custom transformers reading workspace name
  • May 6, 2014 11:32 PM UTC
  • 125 views
bmac
Participant
I want to include the workspace name as part of some metadata I generate
Running the workbench as a workspace the $(FME_MF_NAME) variable returns my workspace name Once I convert it to a custom transformer (CT)  this variable returns the fmx name rather than the calling fmw name
I set a published parameter to the value of the $(FME_MF_NAME)  in the CT
Running as a Linked CT I get the following error
Starting translation...
Undefined macro `ArcGIS_MetaItemDescription_FME_MF_NAME' dereferenced in file `C:\\Users\\scooter\\Documents\\FME\\Transformers\\ArcGIS_MetaItemDescription.fmx'
Program Terminating
Translation FAILED.
Running as an embedded CT I get the correct result
When I embed and run it using a private parameter I get the same error
Undefined macro `ArcGIS_MetaItemDescription_FME_MF_NAME' dereferenced in file `C:\\Users\\scooter\\Documents\\My FME Workspaces\\wb-xlate-1399417605939_8048'
Program Terminating
Translation FAILED.
I really would prefer  to use this as a linked CT using a private parameter
Pretty inexperienced in terms fsuing CT and passing parameters so hoping someone can help
Thanks
Brian
Best answer by david_r
not sure this is doable since the .fmx basically is like its own workspace (if my understanding is correct).
However, I suggest you use the following snippet in a PythonCaller inside your custom transformer to dump all available macro values to see if any of them fits your needs:
import fmeobjects
import pprint
def showAllMacroValues(feature):
    pp = pprint.PrettyPrinter(indent=4)
    pp.pprint(FME_MacroValues)
David
  • May 7, 2014 11:05 AM UTC
import fmeobjects
import pprint
David
bmac
Participant
  • Participant
  • May 8, 2014 4:55 AM UTC
Hi David,That exposed a master name that i could use to get the job done.  THanks for your help
feature.setAttribute("_metaWorkbench", FME_MacroValues['FME_MF_NAME_MASTER'])
cheers
Brian
