CSS Selector for HTML Extractor
  • Nov 12, 2023 3:57 PM UTC
  • 111 views
checcosisani
Forum|alt.badge.img+14
I treid to use css for this website
https://www.servizipubblicaamministrazione.it/servizi/saturnweb/Pubblicazioni.aspx?RicCro=1&CE=brnttcn1113
and I'm able to extract the value oggetto using
tr:nth-child(-n+10) > td:nth-child(3)> a> span but I can't extract the title part because if I use
tr:nth-child(-n+10) > td:nth-child(3)> a I receive back all the values
can you help me ?
thx
Francesco
PS I read the documentation but I'm not able to find a solution
hkingsbury
Forum|alt.badge.img+73
  • Nov 12, 2023 7:28 PM UTC
Seeing that that data is in a table, i'd look to use the HTML Table reader
  • Nov 12, 2023 9:47 PM UTC
Hi @checcosisani​ ,
I agree that HTML Table reader is an easy way to extract each column value from the HTML table.
However, if you mean that "title part" is "DETERMINA AREA SERVIZI ALLA PERSONA N° 126 del 10/11/23" in this string for example, you will have to split this string into two parts - before and after "Oggetto:".
In this case, you can use AttributeSplitter (Delimiter or Format String: Oggetto:) to split this string into two parts.
DETERMINA AREA SERVIZI ALLA PERSONA N° 126 del 10/11/23Oggetto: APPROVAZIONE DOCUMENTAZIONE PER LO SVOLGIMENTO DEI MERCATINI DI NATALE 2023
