Creating attributes as Values for a new attribute
  • Jun 3, 2014 3:03 PM UTC
  • 5 replies
  • 68 views
Hi there!
I'm a bit stuck with something that couldn't possible as hard as I'm finding it to be..
I have a folder with a bunch of shapefiles in, and I simply want an xls output (fanned out by fme_basename) with an attribute that lists all the attributes in each shapefiles.
So in other words, my workspace creates a tab for each shapfeile, but I can't figure out how to just list all the attributes present. I simply want to know which attributes are present. Here's an example of what I'd like:
"ROADS": (imagine this is one of the xls tabs)
"Present Attributes" (This is the field/attribute I create for each tab)
"user"
"date"
"direction"
"type"
etc etc..
I hope this explination makes at least some level of sense.
Thanks in advance,
  • Jun 3, 2014 3:17 PM UTC
have a look at the "Schema (any format)" reader.
Also look at the response from 1SpatialKaty to the question by user sbaktzg just below.
David
Hi David,
I see no link or answer present from "1SpatialKaty" in your post.
Greetings,
  • Jun 3, 2014 3:53 PM UTC
I was referring to a question posted earlier today. Here it is (https://safecommunity.force.com/CommunityAnswers?id=906a0000000d1LfAAI).
David
  • Jun 3, 2014 3:54 PM UTC
Well, yesterday, actually... :-)
Hope it helps.
David
gio
Forum|alt.badge.img+15
  • Jun 12, 2014 12:55 PM UTC
it is also possible to use an attributeexploder for this.
You could use a advanced browser to read all shapes in the folder.
Then write a excelfile with just the _att_name attribute from the exploder.
Excelwriter  could be set to a attribute created linked to 'SourceDataset_SHAPE' parameter . (click little black arrow in attributecreator, select "Link to parameter")
Or like in articel above dst_file = FME_MacroValues['SourceDataset_SHAPE'] (wich is basicallly the same)
