Create Multiple Parameters in Scripted Python Parameters
  • Feb 2, 2018 6:37 PM UTC
  • 7 replies
  • 118 views
I have my parameter values in a SQLite table. I am able to access each value though a Python scripted parameter that opens the table and retrieves the value. However, this means that I have to open and close the SQL table one time for each parameter. Is there a way to make multiple parameters that can be read by the readers and transformers, perhaps in the Python startup script?
Best answer by takashi
Hack. You can define the dictionary as a global variable which can be accessed while FME is configuring user parameters. e.g.
First scripted (Python) parameter:
global a
a = {'ap':'apple','ba':'banana','ch':'cherry'}
return a['ap']
Second scripted (Python) parameter:
return a['ba']
Third scripted (Python) parameter:
return a['ch']
Note: A global variable defined in a scripted (Python) parameter can be used only in scripted (Python) parameters. It cannot be used in the Startup/Shutdown Python script, PythonCreator, and PythonCaller in the workspace.
Hi @jimo
you could create one helper Python scripted parameter that would carry e.g. comma separated values for all your parameters. Then every parameter would be a scripted parameter as well and would retrieve its part from the comma separated helper parameter value. Please find a very simplified example attached.
  • Feb 2, 2018 9:06 PM UTC
I get the concept. Now instead of returning a string from the helper scripted parameter, I can return a dictionary that I create from my SQLite query:
return a
Then in the second scripted parameter I do an eval() on what is returned  by the first scripted parameter to turn it back into a dictionary, then extract the key:
dictParam = eval(fme.macroValues['PARAM3'])
return dictParam["ap"]
The value of PARAM4 is therefore "apple"!
return a
Does this work? I didn't know you can return a dictionary as a param value - this is awesome! Thank you for posting your reply!
  • Feb 2, 2018 10:19 PM UTC
return a
Yes, you can return a dictionary, but the next scripted parameter receives it as a string. That's why you have to do an eval() on it in PARAM4, to turn it back into a dictionary.
  • Feb 2, 2018 11:50 PM UTC
global a
return a['ap']
return a['ba']
return a['ch']
  • Feb 3, 2018 8:21 PM UTC
global a
return a['ap']
return a['ba']
return a['ch']
Even easier, @takashi!
  • Feb 5, 2018 9:53 AM UTC
global a
return a['ap']
return a['ba']
return a['ch']
Agreed, this is a good trick and I do something similar pretty much all the time.
