Create Attribute whose value is dictionaty
  • Mar 7, 2019 10:40 AM UTC
  • 87 views
jugoslaviaa
Hello,
I have a Geojson file. I would like to create a new key-value pair in properties.
Current properties of an object looks like it.
  "properties": {
    "name": "Seattle",
    "type": "CITY",
    "template": "Prohibited",
    "id": 1,
    "TRANDESCRI": "MAJOR TRANSIT ROUTE",
    "SLOPE_PCT": 1,
    "PVMTCATEGO": "ART",
    "PARKBOULEV": "N",
    "SHAPE_Leng": 666.1146823345148,
    "_related_candidates": "0"
And I would like to create new key in properties which is called 'description' and it should have the other key-value pairs in it. So it should look like this
{  "properties": {    "name": "Seattle",    "type": "CITY",    "template": "Prohibited",    "id": 1,    "TRANDESCRI": "MAJOR TRANSIT ROUTE",    "SLOPE_PCT": 1,    "PVMTCATEGO": "ART",    "PARKBOULEV": "N",    "SHAPE_Leng": 666.1146823345148,    "_related_candidates": "0",    "description": {      "name": "Seattle",      "type": "CITY",      "template": "Prohibited",      "id": 1    }  }}
or  (description is a list here)
{  "properties": {    "name": "Seattle",    "type": "CITY",    "template": "Prohibited",    "id": 1,    "TRANDESCRI": "MAJOR TRANSIT ROUTE",    "SLOPE_PCT": 1,    "PVMTCATEGO": "ART",    "PARKBOULEV": "N",    "SHAPE_Leng": 666.1146823345148,    "_related_candidates": "0",    "description": [{      "name": "Seattle",      "type": "CITY",      "template": "Prohibited",      "id": 1    }]  }}
Thanks in advance.
  • Mar 7, 2019 11:36 AM UTC
Hi @jugoslaviaa, the text is similar to a JSON document. I think some JSON transformers could help you to extract required elements from this text.
What string should be finally created from this?
jugoslaviaa
  • Mar 7, 2019 12:02 PM UTC
My file in geojson format and properties looks like this
  "properties": {
    "name": "Seattle",
    "type": "CITY",
    "id": 1,
    "SLOPE_PCT": 1,
    "PARKBOULEV": "N",
And I would like to generate new key -description which is a list of other keys and values which are already in properties
  "properties": {
    "name": "Seattle",
    "type": "CITY",
    "id": 1,
    "SLOPE_PCT": 1,
    "PARKBOULEV": "N",
    "description": {
      "name": "Seattle",
      "type": "CITY",
      "id": 1
  • Mar 7, 2019 1:14 PM UTC
A basic way is to use the JSONFlattenr to extract all members as feature attributes and expose their names, then re-construct required JSON document with the JSONTemplater. The template expression looks like this.
    "properties": {
        "name": fme:get-attribute("properties.name"),
        "type": fme:get-attribute("properties.type"),
        "template": fme:get-attribute("properties.template"),
        "id": fme:get-attribute("properties.id"),
        "TRANDESCRI": fme:get-attribute("properties.TRANDESCRI"),
        "SLOPE_PCT": fme:get-attribute("properties.SLOPE_PCT"),
        "PVMTCATEGO": fme:get-attribute("properties.PVMTCATEGO"),
        "PARKBOULEV": fme:get-attribute("properties.PARKBOULEV"),
        "SHAPE_Leng": fme:get-attribute("properties.SHAPE_Leng"),
        "_related_candidates": fme:get-attribute("properties._related_candidates"),
        "description": {
The JSONTemplater supports to execute XQuery expression with JSONiq extension. This advanced template expression does that with no flattening operation. Assuming that a feature attribute called "_json" stored the source JSON document.
    let $properties := fme:get-json-attribute("_json")("properties")
    return {
        "properties" : {|
            $properties,
                "description" : {|
                    for $name in ("name", "type", "template", "id")
                    return {
                        $name : $properties($name)
