Copying files to two different destination folders
  • Apr 10, 2025 3:37 PM UTC
  • 147 views
enrico.artini
Participant
Hello
I would like to copy files contained in an input folder to two different destination folders using filecopy writer, but I can't set two different destination paths.
Do you have any suggestions?
Thanks a lot in advance
Enrico
geomancer
Forum|alt.badge.img+71
  • Apr 10, 2025 3:54 PM UTC
You can use 2 writers in parallel, both with a different destination folder.
enrico.artini
Participant
  • Participant
  • Apr 11, 2025 8:51 AM UTC
Thanks, I tried but if I insert two FileCopyWriters, when I change the destination File Copy Folder on one, it automatically changes on the second one too.
Where am I going wrong?
Thanks a lot
  • Apr 11, 2025 9:07 AM UTC
Hi ​@enrico.artini
Make sure that two File Copy writers appear in the Navigator window and each writer destination dataset (folder) links to different user parameter.
enrico.artini
Participant
  • Participant
  • Apr 16, 2025 10:13 AM UTC
Hi @geomancer and @takashi,
thx now works.
best regards
Enrico
