Copy files with systemcaller > multiple files
  • May 18, 2021 6:48 AM UTC
  • 195 views
michiedem
Forum|alt.badge.img+7
Novice question (my DOS days are very, very far behind me). I am trying to copy files (photo's) from one location to the other using system caller. The problem I encounter is that only the first photo get's copied. I use this line in the systemcaller:
F: && cd F:\\folder\\photos\\ && md 10122019location && copy F:\\projects\\2019\\location\\drone\\fotos\\\\DJI_0503.JPG F:\\folder\\photos\\10122019location\\DJI_0503.JPG
Of course the photo name changes for every photo I want to copy using @value(photofilename), but it only copies the first photo. How do I copy all?
I do not want to copy all photo's in the source folder, else I could use *.JPG.
nielsgerrits
Forum|alt.badge.img+67
Why not use the File Copy Writer?
If you want to use the SystemCaller you can just use the copy command.
COPY "C:\my work\some file.doc" "D:\New docs\newfile.doc"
Generate this commandline for each file and run it.
michiedem
  • May 20, 2021 7:40 AM UTC
Thank you!
I endend up fixxing it by generating a long line with path\filenames seperated by &&. That also worked. I'll try your suggestion as well just to learn something new.
