CONECTION TO ARCSDE
  • Jan 31, 2019 12:55 PM UTC
  • 49 views
fer_ruiz2
i have problems to configured.
i dont know that name to gdb put in. becasue i conect from Arcmap, only see the folder what i can conect. but the name gdb ¿?
what can i do?
rahulsharma
Forum|alt.badge.img+12
Hi @gamez, It appears that you are having trouble trying to connect to ArcSDE Geodatabase.
Open Workbench, Click on Add Reader
For Reader Select Esri Geodatabase (ArcSDE Geodb)
Under Parameters --> Connection File --> Select the Connection file , should be strored as *.sde
Here is a shortcut to default location where the these files are stored. (%AppData%\\ESRI\\Desktop10.6\\ArcCatalog -- Given if you have ArcGIS 10.6 installed )
Under Table List you can pick up the Table you want to read.
It appears that if you are asked to Name of GDB, that implies that you are not using ArcSDE Reader but instead Esri Geodatabase (File Geodb)
Please let me know if this works for you.
