Conditional value doesn't work properly ?
  • Feb 15, 2017 10:08 AM UTC
  • 152 views
lifalin2016
Forum|alt.badge.img+42
I've just run into a curious problem with a conditional expression in the AttributeManager.?
I'm comnparing two dates in the "FME Date" format (%Y%m%d), setting an "expired" value to either "true" or "false" based on the conditional expression: @Value(dt1) > @Value(dt2)
But it seems like the expression is always satisfied, so my output is always "true", regardless of the values involved (and some should definitely yield "false").
As a workaround I added a Tester transformer, with the exact same expression, and that worked as expected.
Has anyone else run into this, or have any insight into why the conditional value errs ?
Cheers
Best answer by takashi
Hi @lifalin2016, you have renamed "col2" to "CreatedDate" before setting "Expired".
"col2" has been missing after renaming, and a missing attribute will be interpreted as an empty string in test clauses. I think it's the reason why "Expired" became always "true".
lifalin2016
  • Feb 15, 2017 10:44 AM UTC
Here's a sample workspace that illustrates the problem:
condional-value-error.fmw
  • Feb 15, 2017 11:10 AM UTC
lifalin2016
  • Feb 15, 2017 12:16 PM UTC
Doh!
Grrr. Why in %¤#/& does it provide me with "col2" if it's renamed?? The value was inserted by simple point and click, so the interface is unfortunately not as user friendly as it ought to be.
Thanks Takashi.
