Conditional processing based upon published parameter on dataset level (not for each feature seperately)
friesewoudloper
My workspace has a published parameter `area` which can have the values `country` or `province`. It also contains a SpatialFilter transformer that only needs to be executed if `area = province`. How do I evaluate whether this condition is met only once for the entire dataset? Because I have hundreds of thousands of features, I don't want to evaluate the condition for each feature seperately. I would like to do conditional processing on the *dataset* level in stead of the feature level, so Tester and TestFilter are probably not the solutions I'm looking for.
Best answer by redgeographics
If you use a Creator and TestFilter you can test the parameter just once and then use FeatureReaders to do the actual reading.
Forum|alt.badge.img+50
  • May 22, 2019
nielsgerrits
Forum|alt.badge.img+54
This. I never understand why people are still using classic readers?
Old-school FME nerd :) I find it hard to break old habits, but you are absolutely right, FeatureReaders and -Writers do offer a lot more flexibility in complex workflows.
jdh
Forum|alt.badge.img+28
  • May 22, 2019
For most users it easier/faster to drag and drop the file(s) to be read, then set up a creator/featureReader.
jdh
  • May 22, 2019
You may also wish to vote on the following idea: https://knowledge.safe.com/content/idea/61178/parameter-flow-control.html
